"HI, I HAVE A MARINER 175EFI, 1996 MODEL.WHEN GETTING UP ON PLANE OR LOADING ON THE TRAILER, THE MOTOR WILL "JERK" EVERY FEW SECONDS. AFTER THE BOAT IS ON THE PAD IT RUNS FINE. I DIS-ASSEMBLED THE LOWER UNIT COMPLETELY ONLY TO FIND THE UPPER BEARING ON THE DRIVE SHAFT WAS VERY LOOSE (LOTS OF PLAY). THE GEARS LOOK FINE WITH LITTLE WEAR. COULD THIS BEARING BE THE PROBLEM AND CAN THE GEARS BE MEASURED FOR WEAR? THANKS"
