benjamin_jones
"My 115 Mariner CDM type has a
"My 115 Mariner CDM type has an erratic warn buzzer and engine cut-out.
Happens when cold or hot. All throttle openinings and at any constant throttle position. Some days it does not happen at all.
I bought the motor second-hand and I'm not sure of the service history. The motor has had a powerhead overhaul by pvs owner. The control box (series 2000) is 100% functional.
Full service just been done, plugs, impeller and lubes.
I've been told to isolate the yellow/black wire from the circuits.
Also to check the oil and heat sensors signal leads for false readings. How do I do this?
Motor runs at correct temp, using oil on autolube as needed and tell-tail is strong.
Are there any other tips?
Kind regards!
Benjamin."
Kind regards!
Benjamin."
