"Alan,
It is very unlikely
"Alan,
It is very unlikely that all four coils would break down at the same time, but not impossible.
Why did you have to replace the flywheel? What kind of components did you use when you replaced everything?
You really need to start at the beginning and test each component. You need a peak reading voltmeter to do this accurately, but since there is no spark at all you might get by with an ordinary multi-meter. An analog meter is more useful for this purpose, unless of course you have a peak reading meter.
Start with the stator. Check for A/C voltage between each stator lead and ground. You should notice a good reading here.
Check the trigger next. Disconnect the trigger leads at the switchbox, and test them separately. Red lead on a trigger lead; black lead to ground. Meter set on milli-amperes. You will not get a true reading, but you will notice the needle jump on an analog meter.
Next test switchbox output. Again, you won't get a true reading, but with the meter set on D/C voltage, you will get a good jump on the needle.
If any of these tests show no movement on the needle, you probably have found the problem.
Are you sure that you used the proper flywheel? There is some variation here. Some look interchangeable, but are not.
Tony"
