Almost too much to put here...but here I go...
Tige 2005, 24 hours total. 2 summers ago it was running rough, took it into the dealer for 20 hour check. They added stabilizer said it ran fine. I didn't get out that year. Last year went to start it up, but it wouldn't. The fuel pump would not engage. After weeks of diagnosis, replacing the circuit board that has the fuses in it and more diagnosis, the fuel pump still didn't engage. But the engine would fire if I squirted start fluid in it. This year I decided to tackle the problem again. After several weeks of diagnosis, I decided I had a problem with the ECM. So I sent it to Marine Power, and they pronounced it dead. Bought a new one, installed it. The fuel pump fired as soon as I turned on the key.
Now the engine wont start. I have fire to the plugs (pulled a wire, put in a plug, grounded it, cranked the engine). I tried using starting fluid, but nothing.
I know the 3 things are fuel, fire and compression.....but...not sure what is going on....any ideas...I am tapped out...
Thanks,
Thanks,
