MARIN 75HP FOULING #1 PLUG
ajp
I had a split plug cable to #1
I had a split plug cable to #1 cylinder so i replaced it but now the plug keeps on getting fowled has any body any ideas.
"Frst thing as always is to do
"Frst thing as always is to do a compression check!
If that one cyl is low then shoot some 2 stroke oil in there and test again / if comp comes up with oil in cyl./ rings are gone in most cases.
then you will need to tear down and determine the damage to cylinder,piston etc...
In any case the comp test is a Must do !"
