J
John Stone
Guest
"Hello _ Many Questions... I j
"Hello _ Many Questions... I just purchased a 1970 Glaspar not sure of weight? Boat is in great shape for the year and believe it will work well for my need (striper/sturgeon fishing 3-4 persons) It came with an 85 HP Force not sure of year and wasnt able to locate model/serial # as of yet. Motor looks in decent shape. My best guess is that it is a 1986 in comparison to pictures Ive seen although it has a small chrysler symbol at back of housing. It is missing the key ignition switch which options do I have here? Also the old owner says he couldnt get it to turn over much without taking out the plugs. Bad starter? need specific replacement? since there is no key are there any reasons not to jump terminals on silinoid to test/start motor before spending money on fix? There are two sets of battery cables from motor, do both need to be connected? and if so, need two batteries? Prop is in bad shape and does not look to fit motor any suggestions on prop size and material? (not afraid to buy decent prop)and lastly not real familiar with force engines other than seeing a few broke down on water...Is this motor enough for this boat or should I fix and sell/part out?
any and all help would be appreciated. Hope to try starting motor in the morning to see if I need to look for new one. Paid only $300 for boat motor and trailer great deal and expected to need another motor but thought I should give this one a try as I was told it should run.
Thanks Much
John"
Thanks Much
John"
