Manuel Tilt Lever
silkscreeners
"I have a 1976 johnson 70hp ma
"I have a 1976 johnson 70hp manual tilt. When running down the lake should it be locked in, or lever in the up position so if you hit a rock the motor will tip up? Thanks, Brian"
"Lock it so that if you sudden
"Lock it so that if you suddenly need reverse, it will not fail you. If you hit something hard enough, the lock assy will release itself."
"I have a 1965 Evinrude fisher
"I have a 1965 Evinrude fisherman 6 hp,Unable to tilt engine.The trim pin looks like it is knocked out off place and jammed.How do I repair it."
