michael_l
"I am in the process of replac
"I am in the process of replacing original log style V6 manifolds with OSCO center rise (no OEM available). It is a fwc system and in the old setup there is a ss block off plate between manifold and riser in addition to gaskets. The fresh water mounting kit supplied by OSCO only has the gasket that blocks off the flow, no stainless plate. Is this suficient or do I need a blocking plate? Also, Is the manifold/riser gasket installed dry? Thanks, Mike"
