Mallory distributor/318 motor
golden515
I am replacing distributors on my Marinette, it came from factory with E/I, I need help wiring to the ignition module. I have seen other posts that have eliminated the ballast resistor.
The ignition module is inside the Mallory units and does not need a ballast resistor. Take a volt meter and locare the 12 volt end of the balast resistor (ingition ON). Connect the Mallory here and toss out the rest of the Chrysler wiring.
Jeff
What kind of coil do I need to get, NAPA has asked if I want one for a system with an internal resistor or external resistor. I don't want to ruin my new distributors. I think someone put a car coil on motors. Always had trouble.
Thanks for your help.
Can you clarify E/I for us?
What was existing, and which new Mallory ignitions are you going with?
Thats Electronic Ignition.......Rick!! and Mallory only offers the YLM579 which will cause him headache if he has a counterrotation engine
Apparently the YLM579AV works for either LH (std rotation) or RH (REV rotation) engines.
This has to do with the camshaft drive gear cut, and distributor driven gear cut.
attachment.php
YLM579AV MALLORY ELECTRONIC DISTRIBUTOR, This electronic distributor will replace the distributor in a Chrysler small block LM318 and LM360. Both Right Hand and Left Hand rotation engines. Self contained within distributor body. Mallory "YLM" series electronic ignition distributor. Orginal Mallory part number YLM579AV. (also sold as Sierra part # 18-5497-1). NOTE: use with MAL9-29716 coil and spark plug wire set 3745214-MMD.
source
golden515, I think that this would be a good choice in that these are VR triggering.
This is a tried and proven technology, and initally by Chrysler Corp in the early 70's.
Mallory has done a nice job at adapting VR technology into the Marine world, IMO, be it for Ford, GM or Chrysler.
Negative GhostRider.........................the pattern is full!!!
Im checking my toolbox for a tool that will stretch metal, Oh about 1/2 inch is it??
You are right about the cut.................Dead on balls,fits like a glove
