Mallory dist chysler 440s
donsense
"I RECENTLY REPLACED BOTH OF M
"I RECENTLY REPLACED BOTH OF MY DIST ON MY 1973 440S. IN DOING SO I HAD TO REMOVE THE OLD SLEEVE THE DIST FITTED IN TO MAKE THE MALLORYS FIT,STARTED BOTH ENGINES RAN FINE,IDLED FINE,NOW I AM WONDERING IF DOWN THE ROAD IF I WILL RUN INTO ANY TROUBLE BY REMOVING THOSE SLEEVES.
THANKS........DONSENSE"
You might. The reverse rotato
You might. The reverse rotator motor puts the thrust load on the distributor the other way. I hope Mallory thought of that.
THat sleeve was used by Chrysler with a special thrust bearing in the distibutor.
Jeff
