I have a marine power 350 carbureted engine. When the engine is cold and I start the engine it starts fine runs for a minute or two then pops the main breaker.. I turn the key off and reset the breaker and everything starts and works fine with no problems after that... I check the obvious things like tight connections plugs seated correctly etc. What would draw that much only on startup? Sticky relay somewhere?
CSM
CSM
