jhogan0101
new engine, overheated. long story. runs like crap now. compressions are good.
idles very low, stalls when cold. idles when warm
cant go past 2000 rpm under load, in neutral can rev higher to about 3500 rpm
parts replaced so far
IAC
IAC foam muffler
TMAP sensor
TPS
PCV
Ignition coil pack
cap/rotor look good inside
wires are tight
performed smoke test into butterfly while running, no leaking seen.
Tried different external fuel tank new gas
oil level good. no bubbles or milk seen
heres on diacom today
https://youtu.be/6vQK_l2HrP4
IAC
IAC foam muffler
TMAP sensor
TPS
PCV
Ignition coil pack
wires are tight
