H. I. McDunnough
My question is, "Where do I set my timing at?"
My motor is a '78 40B Mariner. It has a magneto ignition. I did enough research to finally figure out how to set timing on a magneto. I got the proper tools and set it according to the manuals specs. Well, sort of, the manual called for a dail indicator reading of 0.165 to 0.177 BTDC. The TDC mark on the flywheel was right on. There was another factory mark at 0.185 BTDC on the flywheel, so I set full advance there, because there was a mark at both no. 1 and no. 2 sides, so it would fire at axactly 180 deg. There was no decal on the flywheel to set full retard. The manual called for 4 deg. BTDC. Full advanced was suppose to be 26 deg. So, I measured the distance on the the flywheel, divided it by 26, then multiplied it by 4 to get a measurement from TDC on the flywheel, and set full retard there.
These settings were far from it's current settings, but I wasn't surprized, so far, everything on this motor has been monkeyed with. Although, I was a little concerned with the full retard setting, as I could see where the unpainted part of the stop screw was exposed, revealing a differance from factory setting.
I adjusted the throttle controls, the idle speed, and the fuel mix to these settings.
I took it out a few times. It idles smoother than ever (I also put a differant carb on). It moves though heavy seas better, giving me a better ride (I had it bored 20 over and fixed a head leak). It responds to the throttle well and does'nt wind-up like, like it used to.
What concernes me, is that I've lost 2mph. At 5000rpms it is at 25mph. The next 500rpms are very uneventfull; a whopping 1mph. I'm not that concerned with speed, but I wonder if I retarded the timing too much. I attempted to advance the timing later, but when I got everything set up, the advaced setting measured around 0.173 to 0.177(maybe that's an issue), putting it with in the manuals range. So, I did nothing, but I am still wondering where I should set the timing. I know that there is a lot going on here, but I would appreciate any help, at all, sorting this out. Thanks.
