1958 35 hp Johnson Javelin
Mag plate has a lot of play in it. Axial and radial play. When motor runs you can see it bounce around and hear it "clacking".
Have tried changing out support and ring with used replacements. No difference. Have tried fitting used replacement mag plates. A bit of an improvement but still play.
Is it possible that the crank collar on the block is worn?
How much play is "normal" ?
