whaler_warner
Hi,
As per title each of the carbs have a small plastic inlet barb for the fuel hose to attach to, on my motor the top and middle are split and weeping fuel which obviously is not a good situation to have.
I have checked the parts diagrams and these are not listed as a changeable part, has anyone else had this problem and have a solution?
I did find a part for a Harley Davidson as they appear to have a similar issue with plastic cracking due to heat/age/vibration and is made by the same manufacture (KEIHIN) however this part is only a right angle all brass inlet, however I am not sure if this will fit and also what to do about the middle carb which has a "T" Shape inlet to allow fuel in and then onto the top carb?
