Jeff, I'm not into the Chrysler engines as you are, so I'm at a disadvantage here.About 25 degrees total advance at 2,500 to 3,000 rpms.
Jeff
Well, thanks for that, and I can probably speak for Jeff as well........., but hold on here.... we haven't quite solved your problem yet!Thanks Jeff. You, Rick and all the other regular contributors make this a great forum!
I'd agree that if we found a perfectly running 440 Marine Engine, we could check and plot this out on paper.When all else fails, reverse engineer!
So lets plot one thats running and see where it goes.
Add more tic marks to the question I asked, say 3000, 3500, 4000, 4500, 5000, 5500.
At first glance it may seem complicated to understand, but its actually quite simple!You guys are starting to get over my head but don't stop now!! I am just looking for the right answers so I can avoid the detonation issues. Thanks one and all.
Jeff, sorry about the wrong image....... My bad!I hope THAT piston shown is not put in a 440 Chrysler since it belongs in a Merc outboard!
Jeff
Dan, the 30 degrees must have an RPM associated with it.I have been running my 440s for many years and I think the total timing runs about 30 degrees.
Woodie, I have a few questions and comments:This is what I got:
Timing: 5 deg BTC
Distributor advance:
0 deg @ 275 - 425 rpm
0 - 7.5 deg @ 425 rpm
12.5 - 14.5 deg @ 700 rpm
19 - 21 deg @ 2200 rpm
This is what I got:
