#1
Today, 04:24 PM
a1nowell
Seaman
M/C 470 Still Heating Up!
Two weeks ago my M/C 470 heated up while out fishing. Here is what I found and steps taken to cure the problem:
1)Took the outdrive off and found the plastic tube melted. The impeller was in tack, not damaged.
2)I got a w/p rebuild kit, rebuilt the pump, new impeller, new gaskets, new plastic pipe.
3)Removed old voltage regulater and have direct hose connection from transome seawater pipe to heatexchanger.
4)Flushed seawater pipe from the gimble housing thru the transome and back again.
5) Flushed the seawater side of the heat exchanger and both ways ,in and out all flowed good
6 Flushed the engine water side of the heat exchanger both inbound and out.
7) Replaced the thermostate (also tested it before installation).
Tested the engine in the drive in a 55 gallon rain barrel with water above both sterndrive finns.
Tested it with the muffs on.
The temperature rises very slowly probably 10 to 12 minutes until it gets to about 160. Then it continues to rise but slowly, at about 1200 RPM. I turned it off before the temp reach 200.
Any suggestions?
a1nowell
Seaman
Any suggestions?
