Quicksilver
Advanced Contributor
Before you launch this season it's a good idea to grease the driveshaft splines (the sides only) and the shiftshaft ones too and, take the prop off and put some Perfect Seal or anti-corrosion grease on the shaft. I have attached a lubrication chart that identifies some key areas that should be greased or oiled. This is a large list - you don't have to do all of them.
