I removed the lower half the alpha one to replace the water pump impeller. The lower half went back into place like butter, but at that point I realized I had mucked up and remembered that I forgot to disconnect the speedo tube when pulled it off in the first place (months ago). When I did that, I accidentally pulled an extra 12 inches of tubing out with it. So, to fix this, I removed the lower half again, and then the upper half. I found where the tube was disconnected and reconnected it. I replaced the gaskets and seals while I was in there and put it all back together.
Now this time I can't get the lower unit back onto the upper half. I'm about 1" away. Not sure exactly what's hanging me up. I read in other posts that the Throttle needs to be in the forward position (in gear). So, I tried that, but notice that the gear shifter mechanism in my alpha one upper half is not completely facing forward. I would say it's cocked at a 20-degree angle. I move the throttle back and forth in the boat, but this gear shift mechanism does not appear to move!!!
I'm not entirely sure how that mechanism works, but I was expecting it to move and now suspect it's what is hanging me up. Can I please get some help on this situation?
