Mountain1952
mercruiser alpha 1 will not stay in gear while trying to install
you gotta hold the propshaft CCW to keep the dog clutch loaded and in gear after you shift into fwdmercruiser alpha 1 will not stay in gear while trying to install
Ayuh,..... I've been using a bungee strap to hold tension on the prop shaft for many years, with, or without the prop on the shaft,.....you gotta hold the propshaft CCW to keep the dog clutch loaded and in gear after you shift into fwd
easiest way is to put prop on and use a bungee to hold it in gear. if you need to turn it to align the splines turn it CCW otherwise it will pop out of gear.
Great, isn't it? Since it has to be shifted into forward for removal/re-installation, the prop/propshaft needs to be rotated in reverse to prevent shifting out of forward.mercruiser alpha 1 will not stay in gear while trying to install
do you just wrap it around the shaft without the prop on?Ayuh,..... I've been using a bungee strap to hold tension on the prop shaft for many years, with, or without the prop on the shaft,.....
