lower unit water in oil
Lic Lic
1995 johnson 175 fast strike, can water leak through the prop shaft bearing carrier. Can i just replace the two large O rings. and not pull lower unit. looking for video
Visit your local shop.-----Normally a pressure test is done to find the leak.---Leak can be at driveshaft seals , shift rod o-rings, propshaft seals and o-ring on propshaft carrier.
