'86 Mercury 75hp. I've dropped the lower unit 5 or 6 times over the years and never paid any mind to the fact that on the underside of the cav plate, I have to remove a NUT from the stud on the port side, and a BOLT on the starboard. I just thought that's the way all motors are. I only know mine.
Now I'm prepping a used motor as a replacement, and I pulled the gearcase, and it has two studs coming straight down from the upper part. Weird. So I looked up the parts diagram HERE (#2 in that diagram), and it shows not only two studs, but that they're threaded on both ends!
So, did someone probably replace the stud on the starboard side with a bolt at some point before me, or did some variants of that motor have a stud one one side, and a bolt on the other? Whatever the reason, I have to get a new 5/8 nut now to put on the stud on the starboard side. And I guess I have to be careful when removing them, that they might loosen from the upper unit side. I didn't know they were threaded on both sides.
