Just bought a 1957 Evinrude Lightwin 3hp. I wanted to check the water pump, took off the 4 bolts and tried to pull off the lower unit but seems the lower unit shaft is stuck to the crankshaft. From what I have researched the two are joined by splines and there are no pins, etc. I tried (lightly) plying but no luck. I thought about trying to pull it apart with some straps and pipe clamps (make shift come-a-long) but afraid I'll damage something. At this point I'm considering bolting it back and just hoping the impeller is OK and move on to the carb and magneto rebuild. I haven't run the motor so don't know if the pump works or not, it def needs carb and ignition work to get it running. Thought impeller replacement was a good first step. Any advice would be greatly appreciated.
