waiting on some parts to complete my lower unit seal kit. while tearing it down, I decided to replace all seals and gaskets. nothing looked like an obvious failure and cause for water leakage, but water is getting in the unit somehow. the only thing i noticed is that the shaft seals under the water pump MAY be the cause as they didnt seem as tight as the seals around the prop shaft are. also going to replace the drain plug o rings. could not pressure test it (i made a previous post when i had a piece break off) this is my first boat motor to work on after years of atv engines.
my question is, does water tend to get in the lower unit from the shift lever or the drive shaft seals more often when there is a failure?
