"HI,
I have a 200 Mariner mfg
"HI,
I have a 200 Mariner mfg'd in 96. When I started it this year I noticed there was little water pressure coming from upper tell tale until i rev'ed it up to1800 or so. I replace the thermostats and got same results. I replace the poppet valve (plastic disk between diaphram and screw convex pointing in)...same result.
I dropped lower unit, installed a new impeller,housing,gaskets etc, installed the key properly. Put the LU back with minimal effort other than lining up shifter spline and water feed. Now I get no water from any tell tale. I assumed I lined up water feed wrong so I tried again...thought I was good but still no tell tale water.
Can anyone help me. I need to know exactly how the water feed (copper pipe etc) goes together and in what order. Not sure I have the guide right.
Thanks,
Joe Reen"
"HI,
Thanks,
Joe Reen"
