signal2noise
"Hi all,
So I changed my l
"Hi all,
So I changed my lower unit oil a few weeks ago and have run the boat since then with no problems. This past weekend I was about to do some work at the transom and I noticed black oil over the entire skeg. I should have looked more closely, but I think it's coming from the hub itself not the lower unit fill or drain plug....based on lack of evidence of an oil track from the fill or drain port to the skeg.
When finishing the oil change I replaced the fill and drain plug. One of them was missing the o-ring seal! I was pretty confident that I didn't lose the seal...but you never know. I reinstalled the plugs.
Is it possible that this missing seal is the problem? Causing me to leak oil? I ordered replacement plugs and will change lower oil again with new plugs this weekend to see if that corrects the problem or if I have something else to trouble shoot (or if I need to get a mechanic for something larger that I can't or don't have time to do).
Thanks in advance."
So I changed my l
"Hi all,
Thanks in advance."
