Moneypit2696
I have Wellscraft 280 aft 1984 boat. This yea when pulled I out of storage found out he bellows were bad and trim senders . tore the out drive a part and replaced the gamble bearing ad bellows and trim senders also the water hose and shift cable . I also replaced the shafts and bushings in the trim unit front ad back. Then replaced the water pump . put the unit back together and had problems with the alinement of it.The top half went on smooth but the lower unit didn't . When I got the lower unit on it stayed in gear in forward gear and in neural but kicks out in reverse the foot comes out of the saddle.
Now after trying to line it up and get it on so many times I have messed up the oil seal on the upper half of the stern drive. How o you replace the oil seal without tearing the whole unit apart.
