Need a second oppion. BF90 199
Need a second oppion. BF90 1997 1800 hrs. running motor and after a few min. heard a loud squealing noise toward lower unit. noise sounded like it was coming from spacer between motor and lower unit where the bushing is for the shaft. pulled foot and checked water pump ok and shaft turns well. saw the seal in the spacer plate was swelled up. drain foot and did not find any metal just the normal wear . have u ever herad of that bushing causing that problem.
Thank you Mike
Thank you Mike
