O
oily
Guest
I have a 1968 Johnson 9.5 HP o
I have a 1968 Johnson 9.5 HP outboard. Used it last week with no problems and this week before taking it out I found a puddle of lower unit lube under the lower unit. Also there was a small rubber plug laying in the puddle. Both filler screws seem to be in place and sealed. The fluid seems to be leaking from a small port on the very back of the lower unit under the exhaust port. Is that where the rubber plug came from and if so is that really all that holds back the lower unit lube is a small rubber plug?
The motor is stored off the boat and transported in the bottom of the boat when driving down the road so I am assuming something rattled loose.
Any thoughts?
Any thoughts?
