I have a 1995 Crownline 225BR with a Mercruiser 350 Mag coupled to an Alpha Gen 2 drive. I noticed after several days of boating that the gear lube in the lower unit reservoir bottle was butterscotch colored. It is Pennzoil brand lower unit gear lube and is golden in color when new. I replaced the impeller and changed the lube this spring and honestly after checking the level after the service I hadn't paid any attention to the color of the lube after we ran the boat a couple of times. I initially was concerned that there was water in the lube, but after four days of sitting on the trailer the lube looks the same with no seperation in the bottle. I cracked both the bleeder and fill screws and the same color of lube came out with no water present. There was never any oil slicks on the surface of the water by the drive at any time. The level has never changed in the reservoir. I searched on the forum and have found suggestions that the oil may just be aerated and that the butterscotch color is completely normal. Just wanting to confirm that this could be normal, that four days is long enough for water to seperate out of the gear lube, and if there is anything else I should check before I smoke my lower unit.
