Donewright
Greetings,
I have a working 1978 150HP engine with a damaged lower unit case. Part of the Cavitation Plate (I think that is what it is called) is broke. I have a good case from an 80's 150hp and they look nearly identical from the outside. Can I replace my broken '78 with the case from the 80's model? I think the drive shaft comes out when you pull the unit off, can i expect the splines to match? I have attached some images. As you can see, the previous owner was pretty rough on it.
1978 Serial number = 5025197
1980's Serial number = OC248098
