troym
Advanced Contributor
"Found the oil leak!
Replaced
Replaced the impeller, changed the oil, etc.
Ran it for retest, everything works great.
Came home from work today and noticed a spot of oil right beneath the skeg. Traced it back and it looks like it's coming out of the oil seals around the prop shaft. Pulled the prop off and confirmed.
Two questions:
1) Do I really need the special tool ($65) to remove the bearing carrier retainer or has someone out there engineered an equivelent with tools found under a typical shade tree.
2) The manual says to remove the water pump first. I don't see the point in that, unless the section I'm looking at is an excerpt from a complete teardwon, especially since I just replaced the impeller and would rather keep the lower unit attached while I replace the prop shaft oil seals. Any comments?"
Replaced
Two questions:
