jmsjohnston
I have a Yamaha 250 4 stroke on my 25' parker that during my "winterizing", I found that the lower drive, prop shaft is bent, and spinning with a little "wobble". Is this a job that I can do during the changing of the impeller replacement that I will have to do this spring? I found that the lower case had about 4 oz of oil left when I drained it out to change the lower drive oil (90) weight)). Took 1 qt. to fill it back up, so I knew I was dealing with a seal problem also. I dont have a problem taking on these "jobs", but if I have to have special tools, then I may as well take it to a person that has the tools to do the job. I would like to buy the parts needed to do the job and just pay the labor.
Any comment would help alot.
Thanks,
JMS
Thanks,
JMS
