I have a 2002 4hp Nissan outboard. The bolts that hold the lower portion of the cowling to the motor have come loose causing excessive noise and vibration of the motor housing while running. I have some access to the two bolts on the prop side, the others are totally obscured by the engine. How are you supposed to tighten these without taking the block off? Any tips?
Thanks,
David
Thanks,
David
