Fishhuntermike
While attempting to remove my lower ends to service the water pumps, I realized that the starboard engine lower end spline is frozen ( corroded ) up inside the engine. I tried tapping it down with a rubber mallet and a 2x6 wrapped in a towel only to crack the cavatation plate. My mechanic wants to cut through the housing and the spline to separate them. Has this happened to anyone else ? If so how did you remedy the problem ? I should mention these are 2004 Suzuki 250s. Any help is appreciated, thanks Mike.
