Your bowl is full of crap also in the carb.
And your tank also.
And your filter that enters the carb in that fitting.
clean carb < Click on this
Copied and pasted here from another site i am the author:
I pumped all the fuel out of my onboard fuel tank when i got it.
You can do one of 2 things, pump the water out of the bottom, or all the fuel out and here is how.
If you just wish to pump just the water out of the bottom of the fuel, you will need to purchase a cheap electric fuel pump from any auto store dc powered.
You will also need about 15 foot of cheap fuel hose from the auto store and clamps to fit the fuel pump.
Install the hose on the fuel pump both ends and cut about five feet on the sucking side of the pump just look for the arrow on the pump.
Remove the fuel pickup tube it's the one where the fuel hose hooks to the tank a 90 degree angel fitting, it's a anti-siphon valve. Unscrew it.
Crank the bow of the boat all the way up, and stick the hose connected to the electric fuel pump 5 feet into the bottom and back of the tank.
Into a clear container pump the water out till you see clean fresh fuel and stop the pump.
Or into a large container pump all the fuel out.
Now check the valve by blowing thru it, check the screen thats its clear.
Install the valve and pickup tube your done.
Question do you have a fuel water separator on the boat, good to have.
Good luck !
