I purchased the boat took it out on the water it was running good fast speed but i was hearing grinding sounds. I shut it down pulled it out and took it to a boat mechanic.
Was this an experienced V/P AQ series mechanic..... or a general marine mechanic?
He confirmed that my suspicion was correct that the upper unit was bad.
Did you confirm this as you pulled it apart?
I was told that
I should purchase a new upper unit and he wanted to charge me $1200 to fix it.
A new transmission (upper gear unit) would cost in upwards of $3,500 or so.
An experienced AQ series mechanic should be able to R&R a transmission in 3 hours or so.
Being the hands on guy I am it was just cost effective to do the work myself and save $900.
Did you repair the transmission, or did you find a good used one?
FYI: since all of the 275 transmissions are of the same reduction, try your best to find a used transmission from behind a 4 cylinder engine.... not from behind a V-8.
I did look at the lower unit disassembled and everything looked fine.
You pulled the prop shaft bearing carrier and examined the gears/bearings?
Did you install new prop shaft seals while you had it apart?
I put the outdrive together and everything looks and sounds fine. I took it into the lake, backed out slow and docked waiting on my friend. As we pulled out I went to accelerate and it just never picked up and went. The engine would rev up like normal but no thrust. Forgive me for lack of knowledge I am by no means a mechanic but I am a bit mechanical. (Blue collar worker that looks up things I don't understand.) I did have debris in the old oil nothing made it past the screen though that I saw.
Is the only way to test the hub marking by putting it in the water? Or can I do that in the driveway? The lake is an hour drive away.
The permanent marker pen is used to make a line through the outer prop hub and the inner hub.
In other words, you would draw a line through both.
The propeller must undergo in-the-water-thrust in order to place enough torque against these two components.
When back on the trailer, if the outer hub and inner hub have shifted, then you know that the hub is bad.
In other words, if your marker pen line has shifted, the propeller hub is not holding.
