Low rpmbs
tyler_w
"I have a TAMD60D that has sta
"I have a TAMD60D that has started running low rpm's at full throttle. It used to run slightly above 2800 as it should and in one day it dropped down to around 2000 on the way back home. I changed all filters and it went up but only to around 2500 rpm's. Used to max out at 23 mph now only does 17-18 mph.
Is there a max rpm screw on the fuel pump that might be the answer? If so where is it etc. I can not find a manual for the fuel pump.
Before I did the filters I had to run another trip and it started fine, as it always does and idled fine thru the no wake zone. As I opened it up it got on plan for a few seconds then lost power. I ran the rest of the trip off plan at about 1500 rpms with no problems or hesitations. could dirty filters cause the pump to need recalibration?
The engine has always had a little white smoke at idle. There is no change in smoke and no black smoke at full throttle."
"Tyler
It sounds like you hav
"Tyler
It sounds like you have had a decrese in fuel flow volume, the engine is not getting enough fuel. Replacing your filters was a good move. There are other things that can restrict fuel flow. You could have a blocked tank pickup tube. bad hosing or air leaks in the system that cause the fuel not to move. It also could be a bad pump. Have someone check the fuel line pressure, this might help poimt you in the right direction"
