RatchitClank
I am trying to revive a 1975 Chrysler Force (Challenger) 90 Hp. The motor has not been running since about 1994. I have cleaned the carbs and checked the compression. (1 - 130, 2 - 125, 3 - 120). The water pump was checked and replaced. The motor starts and runs good in the driveway, (with a water hose).
When I get it to the lake, I cannot get it above 3000 RPM, and it struggles to get there. The pontoon boat will plain out but the motor surges and does not run steady at WOT.
After running the motor for 30 min on the lake, the center plug looks clean but wet. The others are brown and wet. I am not sure why only one plug would not consistently be getting spark with a one coil setup like mine. I measured the resistance/continuity of each wire at 8K-9K, from the boot to the inside of the distributor cap. I have visually checked for spark on each wire, with an adjustable spark tester, although the #2 looks weaker than the others. I have cleaned the inside of the distributor and checked the points.
Any Ideas?
Any Ideas?
