Hi,
I bought this 1979 Pacemaker 33 Sportfish with twin 454 Crusaders recently. The starboard engine's starter would not engage, and the port engine had the heat exchanger off, so I could not test drive it not compression test it.
I compression tested it today and here it is: 1- 110, 3-115, 5-110, 7-110, and the other side 2-75, 4-15, 6-35, 8-85. All of the pressures held up and were run after the engine was run for 15 minutes. I had just replaced the points distributor with the Delco Voyager EST Distributor Kit, and now, what to do? The engine is original and has 1377 hours.
Could the head gasket need replacing, or should i just get a long block or repower? There are so many variations of 454's, with peanut, oval, and rectangular port heads, as well as Mark IV, and Gen V and VI blocks. I like the idea of a roller cam/lifter/rocker drivetrain for the free horsepower. I also see 502's available, but I want dependability and economy, with a cruise of 18-22 knots. I have just replaced the heat exchangers/risers/elbows, and had the oil coolers acid washed and pressure tested, so I would like to stay with the log manifold system.
What are the specs of the 1979 vintage Crusader 454 350HP? What are the shape of the ports on the heads?
Which way is the most economical way to go?
Seth Anderson
Moon, VA
Seth Anderson
Moon, VA
