Chad Noben
I have about 83psi in both cylinders with a new head. Piston and cylinder walls look fine. Should I just throw new rings in? Hone the cylinders? Also I had thought the gears were going out cuz of a very high rev and huge loss of power, so i took the cone off the end of the prop, put it in gear, and turned the prop until it stopped. Then I kinda put pressure on it and wiggle it back and forth/up and down, and noticed the hub moving a little inside the prop? Is that normal or the problem?? Thanks for reading. This forum rocks!!
