I have a 1995 Crownline with 350 Mag and an Alpha drive. The Engine serial number is OF354207. I have been chasing a low voltage/hard start issue since I rebuilt the engine last summer. After I run the blower for 15 sec., the voltage at the key switch will drop from 12.5 to 11.5. When I try and start it it will kickback against the starter and then start but the alternator will not charge until I rev the engine to 1100rpm. Then the voltage will jump to 13.9 and stay there. If I turn the blower off the voltage will go to 14.2. After running for a minute if I shut it off and don't turn on the blower and try and start it the volatge at tge key switch is 12.5 and it will start immediately without kickback and the voltage will jump 13.6. It appears as though when the voltage drops below a certain point the alternator won't charge without a slight rpm increase. It also seems that the blower is drawing alot of voltage and draining the battery. I have had the alternator and battery tested and both are supoosed to be good. I have swapped the battery with a known good battery with similar results. I am at a loss as to where to test from here. Any help is appreciated.
