"First time in the water this
"First time in the water this year and after running for around 20 minutes at 3/4 throttle. A loud squeaking noise (like rubber squeaking) was heard at idle speed. When throttle was increased the squeaking became faster. Took all belts off to eliminate the alternater, power steering and water pump. The noise seemed be coming from the motor but couldn't tell if is was the front at the flywheel or at the back to the leg. The last 4 times out the noise had disappeared. Someone suggested maybe something where the motor connect to the leg. Any comments out there?"
