ShayneCastonguay
I have a 1978 mercury 200 20 hp that i just recieved. It needed a power pack, which i installed, and the motor ran for a little bit before cutting out, but did run. I pulled the carb and cleaned it all out (also replaced the plugs) only to find that the needle valve was sticking closed and no fuel was getting through. I recleaned the carb and adjusted the float, and fuel is now properly in the bowl. But when i pull the cord, i get a loud popping noise, not every time, but more than once. Occasionally, the motor runs one or two cycles and shuts down. Compression is at about 100 psi for both cylinders.
