I have a 1976 starcraft with a 302 ford mercruiser. I just bought it aND took it out on the water. Ran great for a couple days then one day I pulled into a cover and it wouldn't start or fire at all. Checked for spark and it had nothing. Found out the coil had gotten water or something inside of it. I changed the coil and did a tune up with new cap, rotor and points. The engine had a bogging to it at wot so I figured I would clean the 2 bbl Rochester 2 jet carb also while I'm at it. Took it out after everything was replaced and it ran great. Still had a little bog to it though. I was cruising down the lake ando the boat just shut off and I realised it overheated. It will crank over but will not start. I have no spark again. I tested the new coil and have 1.6 between. The + and - and 8600 ohms between the center to both sides. I pulled the cap off the distributer and the plug from the coil to check the point for spark with a screw driver and see no spark. You can hear the buzzer when the key is on change noise when you break the points apart but there is no spark. I am stumped on what the problems are. There are a couple breakers but none were tripped. Any help would be greatly appreciated.
