Lost reverse gear in 1970 95 hp evinrude
wassajet
i have just replaced the impel
i have just replaced the impeller in my motor.Now that i replaced the lower unit i have lost reverse gear it was there before i took it apart.The shift rod is fully seated in it's connection & the screw is tight as it will go.Can someone help me with this problem please...Warren
"yes,it does--66-74 and relate
"yes,it does--66-74 and related parts,..could have slipped during all your assm trbls..i use blue locktite,on those screws as well as the 2 on the brass shifter.
375905.png"" alt=""
"part numbers--> 66-74 and
"part numbers--> 66-74 and related parts,..could have slipped during all your assm trbls..adj to get f-n-r...IF this is ur prob....u may still have a brass connector prob...."
"Thanks for your help once aga
"Thanks for your help once again.This would be the best site i've seen.It's so helpful, especially if you're a novice like me. Good work & many thanks...Warren..."
"Thanks again guys for your he
"Thanks again guys for your help.You were right once again,the problem was #66 & #67 & related parts on the diagram. Once i made the adjustment i got reverse gear back again. Sorry i took a while to respond, i just haven't had the time to work on the motor lately.I'm very grateful for your help..Warren..."
Could it also be that your sha
Could it also be that your shaft rotated during reassembly ? That has happened to me before and the slightest adjustment could make you have too much forward and not enough reverse.
"Yes it may have caused the pr
"Yes it may have caused the problem,i'm not real sure but it's fine now i have all gears.Thank you all for your help & quick & helpful responses...Warren..."
