Lost power in 76 evinrude 70hp
leach
"was at the lake on saturday e
"was at the lake on saturday engine ran fine did about 25 to 27 mph. on sunday a different story boat started fine and ran fine but would only go about 12 mph. went out again on monday night boat still only ran 12 mph. speed-o works fine i have no tach, thinking i should check compression is there anything else that it could be??"
"Ck Comp.... should be 100&#43
"Ck Comp.... should be 100+ psi and even on all cyls.
Ck Spark.... Should jump 7/16" gap with hot spark, a real SNAP!
If above is okay, clean carburetors."
could a half plugged fuel filt
could a half plugged fuel filter and a cut plug wire be my root cause??? found these problems on visual inspect today because it is the first chance that i have had to look at the motor!!!
