cleaned tank out change fuel lower cab was over flowing when i started it after i cleaned the tank i believe it was a stuck float put carb cleaner in it stop over flowing moter runs good at low speed and at high speed would not get to 4500 rpms after puting more cleaner it would perk up run good for a hour tubing then would shut down run only on low speed moter ran grat before the water cantamnent in fuel wondering if high speed jets are the issue or floats thanks
