floatin radio
1990 searay 17' 3.0 alpha 1. 17 pitch prop Carbed. Ok, a little back history that may be relevant.
About 4 years ago I gutted the interior and replaced the stringers, floor and the foam (aero marine ). Re fiberglassed everything. I did not redo the transom. Replaced gimble Berring and all bellows. It has been running fine since, gets up on plane, pulls 3 tubes, pulls skier.
Last time out last year I noticed I as only getting about 3500 rpm, it still gets up on plane but lost mph and 1000 rpm. I replaced all fuel filters , carb, inline and in fuel pump, also replaced anti siphon . Didn't make much difference. I was going to rebuild carb over the winter but never got around to it.
I took it out a couple weeks ago for the first time and was hitting 4300 rpm and it was running well. We floated and swam more than we cruised. When I was heading back to the dock, I had lost the 1000 rpms again. When I pulled the boat out of the water and pulled the plug, about 2 gallons of water came out. Bilge pump never kicked on while we were on the lake, ( 6 hours)
have t checked timing or replace plug wires, cap rotor or points in 4 years.
The foam I put in it was marine grade high density ( doesn't absorb water, or at least not as fast.
is it possible that my transom is where the water is coming in from and is soaking up the water causing it to be waterlogged?
Only two gallons comes out, where ( if any) is the rest of the water? Or is this old engine related?
thanks
thanks
