" First...Thanks to those who
" First...Thanks to those who have helped me in the past!
I hope this one is easy.
Last year, my 1976 Bayliner ran 32 mph @ wot.(4800 rpm) It has a Volvo 170. It would plane in about 8 seconds. The last time I took it out, I destroyed the prop. Over the winter I ordered a new prop using the exact number stamped on the old one (Michigan 082021 15x19) . The first time I took it out this year, the best I could do was 25 mph and would max @ 4400 rpm and I was forced to use the trim tabs in order for it to plane. According to the manual the max should be around 4800 to 5000 @ wot. I replaced the new prop with an old spare to see if the prop was the problem. I was able to plane rather quickly, but the rpm was exceeding specs.( I stopped at 5000 rpm (but only 20mph)with more to give. Here's the question...Is it possible to repitch a prop? I'm thinking the prop I destroyed last year was not the same pitch as the new one, even though I ordered the same model number.
Thanks for your help! "
